Is my heat shield ugly ?
louiswun
How is it ?
cbh148
Car: 2000 Civic Si, 1993 240sx Hatch CA18
I like it. Although, you're right-hand-drive, so I'm guessing you have less problems with melting stuff to begin with.
themadscientist
I did the hell out of that! It looks like a part off a Transformer or a Robotech jet. :yesnod
I went with diamond plate.
ska69
Car: 200sx s13 ca18det
+1 looks like a transformer or an early terminator :) but even provided that I like! I beg you pardon buy why did you change the manifold? bigger turbo and/or going for > 300hp?
float_6969
I like it. Looks industrial. Makes me want to listen to techno music. Strong Bad style.
themadscientist
We gave you the switch so you could turn the light off and on, not so you could have light switch raves.
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
It looks f*cking terrible, you should give it to me
float_6969
:mike :mike :mike :mike :mike :mike :mike
s13drifter88
It looks awesome, what turbo are you running? I noticed your external wastegate.
louiswun
s13drifter88 wrote:It looks awesome, what turbo are you running? I noticed your external wastegate.
It is China made GT2871R 48 Trim
It come with internal wastegate and the accuator it come with is adjustable 0.55bar - 1.0bar,
No matter how I adjust the accuator rod length, the max boost that I can get is 0.85bar only,
So I change to a another up graded accuator, tested before installing, the accuator rod start moving when I apply 1 bar of air pressure,
But on road testing, it only hold at 0.9 bar when boost controller is off, when boost contoller is set at 1.1 bar or any higher,
it still hold at 1.1bar only.
So I weld up the internal wastegate and install the external wastegate.
louiswun
