nnorton44 wrote:I think its on backwards then, the flat colored side goes to a tube that runs with 4 others towards the front of the car and it looks like the left side that isnt flat runs to the tank.
Sounds like it is on backwards then. A few things to consider:
1) Some fuel filters are uni-directional. This may be the case with yours, contact the manufacturer for more info before you go flipping and buying new ones.
2) Even if yours is backwards, the fuel is still passing through the filter element, albeit going the wrong way. Your fuel is still getting filtered before it hits the injectors, but probably not as efficiently as if it were installed in the correct direction.
3) Do not simply flip your filter in an attempt to rectify the problem as it may already have gunk on the fuel tank side. If flipped, the gunk would then be on the injector side of the filter element and the flow would push any of this gunk into the injectors.
What would I do? Buy a new filter and install it in the correct direction just to be safe.
Good luck!
