Is my engine block cracked?
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
1998yellowstang
Car: 2004 Nissan 350Z
I recently bought a used motor from a car that was involved in a collision. After further inspection, it appears to have spider web like cracks on the block. Does this mean that the engine block is cracked, or is there another explanation for this?
WDRacing
It almost looks like a coating that is cracked. I've never seen a block look like that...almost shattered in appearance.
djwarner
Car: 1971 240Z Series I
2006 350Z
Looks like a casting defect when the melt solidified prematurely.
1998yellowstang
djwarner wrote:Looks like a casting defect when the melt solidified prematurely.
If that is the case, then it would just be a visual defect, not mechanical, correct?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Looks normal, aluminum blocks look like this due to the casting process. On high end show cars they sand these casting perfection and stress risers off.
1998yellowstang
evildky wrote:Looks normal, aluminum blocks look like this due to the casting process. On high end show cars they sand these casting perfection and stress risers off.
Your always a ton of help! Thank you!
Return to “350z / 370z Technical”
