tollboothwilley wrote:G35's are not known to have issues with temp readings, although the temp readings have been generally slow to react to overheating conditions sometimes.
Your temp is fine. Don't worry about it.
My temp is fine his may not be. If the temp readings are slow to react to overheating conditions then that is an indication that the readings may not be accurate. Slow to react gauges can indicate a sensor essentially running dry and giving an indication of the temp of the mounting device.
There are many things that can make a temp sensor in a car give less than accurate readings. Depending on the type of sensor it can be high resistance in the cable to it, the sensor itself, a fouled sensor from contaminates which acts to insulate it, even a faulty design of the sensor and its location. That is one reason why many go to a water hose adapter and put in after market sensors. They may cost but they eliminate much of the reasons stock sensors are less than ideal. It isn't even unusual for a quality car to have multiple sensors, one of which is the one you see the results of and often that one is the less sophisticated and least accurate of the bunch since it is not critical.
Another factor comes into play with these gauges and it is they are not linear. They are designed to give a certain reading at whatever is the norm. This may not be any more of a benefit then having a high/low/normal set of lights
If I had any doubts at all, I would not bother with thinking it is correct because someone who has not even seen my car says so, I would prove it which is actually very simple to do. My guess is his is normal, but that is simply my guess since I do not have physical access to his car.
So basically if the poster is worried and he seemed to be enough to take some measures to check it, then he should verify his indication. While you always should initially trust your indication you should always verify it if you have any doubts about its veracity.
Perry
