It's not possible to mantain stock alignment settings when going an inch lower.240sxjeff wrote:Not even close, my car is easily an inch lower than that and I aligned with no problems whatsoever. Just make sure the person aligning it knows what they are doing ie. take it to a reputable shop
Im 99% sure he hasn't even had an alignment yet. Nani- Whenever you mess with suspension stuff, go get your car aligned.240sxjeff wrote:well I assumed he wanted a performance-oriented alignment instead of stocknani: are your wheels balanced? that might be causing your vibration issues
OMG NO! What is with this 'omg stretch is the roxorz' phenomenon?' Just put out the extra cash for stiffer tires and you wouldn't have to compromise wheel safety so much. I like to have *some* sidewall in case I hit a pothole I can't avoid in time. You people are insane. INSANE.PencilShavings wrote:in the first pic your camber does kinda look like a lot
btw, I like the wheels and the strech looks sweet
]Dori Dori wrote:No, your car is not too low. It's actually sitting at a pretty good height.*
As for your vibration issues, your alignment is NOT causing that vibration. Are those wheels hubcentric? If not, are you using hubcentric rings? You might have an off balance wheel, bad tire, or something else is still fubared from your curbing incident.
*fanboys, please refrain from commenting.
Which means absolutely nothing. By your logic nobody would ever have to ever do things like balance wheels or get alignments b/c the parts are the same on all cars.naed240sx wrote:]
hubcentrics aren't causing his problem. I run no hub rings all the time without issues.
His wheel is shaking "like crazy" past 45. I know tons of people including me who have not used hub rings, and never had ANY issues. All that hub rings are gonna do is possibly make the ride a little smoother, if at all. He has some other problem.Dori Dori wrote:Which means absolutely nothing. By your logic nobody would ever have to ever do things like balance wheels or get alignments b/c the parts are the same on all cars.
If the wheels are not hubcentric they CAN cause vibration issues.
It's definitely the cheapest item to rule out...
I can tell you from working in a shop specializing in wheels and suspension that for most all cars I've worked on, non hubcentric wheels will cause the steering wheel to shake violently, starting at around 45 for smaller-wheeled vehicles. Hub rings fixed the problem every time for us.naed240sx wrote:His wheel is shaking "like crazy" past 45. I know tons of people including me who have not used hub rings, and never had ANY issues. All that hub rings are gonna do is possibly make the ride a little smoother, if at all. He has some other problem.
Were you tightening the lug nuts down before putting weight on the wheels? If you tighten the lugs properly, it shouldn't be a problem, because modern wheels are lug centric.SeVa-S13 wrote:I can tell you from working in a shop specializing in wheels and suspension that for most all cars I've worked on, non hubcentric wheels will cause the steering wheel to shake violently, starting at around 45 for smaller-wheeled vehicles. Hub rings fixed the problem every time for us.
Thats odd. I ran some 8mm spacers(when using spacers, hubrings are impossible) on my front wheels for like 4 months, and never had a single vibration issue. I also took off and replaced my front wheels like 6 times during that period. I always just tightened em down decently well before allowing the tire to touch the ground. Im on coilovers too, so it hits bumps hard.SeVa-S13 wrote:Yeah you can usually get pretty close by tightening before you drop the car, but once it hits a decent pothole or something, it will jar the wheel and it will shift. That's what usually happened to us.
ALIGNMENT DOES NOT CAUSE/CURE VIBRATIONS.naed240sx wrote:NANI: Have you even had the car aligned yet? Im guessing not. If this is true, everybody needs to STFU untill you have that done. Alignment is first order of business after a suspension install.
So you're driving around on unbalanced wheels because you think the weight was hitting the spring? WFT? Dude, get some stick on weights and balance your wheels. Your vibration issues are coming from:nani wrote:Ok guys im goig to do the alinegement tomorrow. ill update. I tried balancing the wheels but when i put the weight it was hiting my spring. it did feel a little better tho. but i could not take the bumping sound so i took them out.
Tightening the lugs does not necessarily mean that a lugcentric wheel will align with the hub. Most tire manufactures and wheel manufactures will recommend using a hubcentric ring to ensure proper alignment with the hub.naed240sx wrote:Were you tightening the lug nuts down before putting weight on the wheels? If you tighten the lugs properly, it shouldn't be a problem, because modern wheels are lug centric.
Don't get me wrong though, I do suggest running hub rings, and I run them on my car now. I'm only saying that first order of business is getting the car aligned properly. He can get by with no hub rings.
