alienwareboy51 »
https://forums.nicoclub.com/alienwareboy51-u20457.html
Thu Dec 01, 2005 4:31 am
its simple first do u have a swap or is it stock if its stock first take off the hose going to your cam cover and take it off the intake tube
then u see the fuel rail twards the back of the intake mani theres a saucer like fuel return on two bolts on it , i think their all 10mm take it off the bolts u dont have to remove the hoses
the fuel rail is now accesable its on two bolts holding it to the engine carefully un do them and set them aside a magnet is very useful to keep it allo form falling
then wiggle the fuel rail off (this is where all the fuel from the rail flow everywhere ) this will free up the rail from the injectors to change the top orings but dont do it on the spot take off the wire clips holding each injector(theres a u pin holding each one take a knife and carefully pull the metal clips off and out careful not to drop them set all 4 aside envelopes or baggies are handy)
pull off the clip and remove each injector usually the bottom o ring stays in the mani u make the choice to change them or not if their clan u can leave them
take each injector and use a hook or a ball point bic pen and remove the black o ring from its divet use some brake fluid or plain oil to lube up the metal stem and slip the new ring on (dont get oil into the injector itself if u do its ok but do ur best not to )
go back to the car set each injectrer into the fuel rail push them into the original position wiggle a little to set them well
heres the part that requires a couple more hands then ppl have put the rail and aim all the injectors into their original position push them all in make sure the wire clip is pointing up on the injector
now ur ready to bolt the rail back into place with its 2 boltscarefully push the rail into its final place and use and extantion with the ratchet head to prep each bolt into its original thread now evenly switch between the two bolts tightening them evenly dont over crank them but make them nice and tight
once thats done ensure that the rail is secure and wiggle each injector just a little to reset them in the holes reattach the wire harness and the clip to each one bolt back the fuel return valve to the mani and check that u dont have any extra parts left over
replace the tube to the intake and cam cover and start up the car make sure none of the injectors are leaking or spraying and ur all set 9it may take a couple more cranks to start but thats because the railk is empty
if any of the injecters are still spraying then wiggle them and restart the engine u shuld be all set
have fun post any questions u have
