EW »
https://forums.nicoclub.com/ew-u28959.html
Sat May 28, 2005 3:37 am
A Clifford Concept450 is $399 installed where I work. It includes the following features: starter kill, ignition kill, keyless entry, flashing parking lights, LED, door protection, dual zone impact sensor, glass breakage sensor, water proof remotes, extended range antenna, 15 sound programmable siren, coded valet, dome light supervision, and there is a list of programming options that we set with our laptop after asking you how you want the vehicle to function. The Clifford Intellistart4 module would need to be added for remote start on manual which is $199 installed. When it is installed, you not only get remote start but you also get shortstop which allows you to leave the vehicle running and armed while you run a quick errand (like going into a conveinience store), and you gain hood protection since we have to add a hood pin so the alarm will not attempt to start if the hood is opened. There are many other options like window control, back up battery siren, digital proximity sensor, etc that you can add.So, $399+199=$598+tax installed.
