Is it very hard to change the cabin air filter in a Rogue?
Mrcjolsen
Car: 2011 Nissan Rogue S AWD
I looked online, and it seems pretty straightforward. Just need to know before I buy the filter and commit to doing it.
I know that on some cars, like the Volvo S40, it can be a real pain.
darylzero
No it's very easy. Check out one of the last posts on page 4 and there is a video.
cabin-air-filter-t321326.html
Qashqai
You can read details here: cabin-air-filter-t321326.html
I hate changing the cabin filter of my Rogue, because I need to crawl under the steering wheel (I am not a tiny guy), bend the used filter to take it out (causing dust and debris to fly around and probably fell into the filter chamber) and bend a brand new filter (I am not sure if bending a paper filter is a good idea, leaving creases...).
I recently changed my friends cabin filter for his 2008 Mazda CX-7. It was behind the glove box, in just 4 minutes it was done.
As far as I know Nissan decided to put the cabin filter there to reduce the cost of cars that have drivers on the right.
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
i stick a vacuum attachment in there too to suction some of the debris out. otherwise not bending the paper filter is impossible. and its not a big deal either.
kerrton
Car: 2008 Nissan Rogue SL FWD Gotham Gray
It is an awkward squeeze and you'll probably get some dust in your face, and the first time you do it might take a little longer but like any job after you've done it once the next time will be a snap. There's no way to avoid bending the filter, but its very flexible and pops back to its proper form once it finds its way into position.
This is a great way to save about a hundred bucks, in particular if your order your filters in bulk online it can work out to less than $10 to change out the filter.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
ImStricken wrote:i stick a vacuum attachment in there too to suction some of the debris out. otherwise not bending the paper filter is impossible. and its not a big deal either.
Excellent suggestion! I did that when I changed mine and was quite surprised at how much debris were in there. I too was worried about bending the filter, but that's actually how it's designed, and it pops back into shape just fine. Not looking forward to changing it again as I scrapped the bejesus out my knuckles. The tutorial video was very helpful. Plus I saved $$ over what the Stealership wanted to do it for me. :woot:
ImStricken06
2016 Kia Sorento
Rogue One wrote:Not looking forward to changing it again as I scrapped the bejesus out my knuckles.
i burned the CRAP out of my hand by touching the heater-core (the radiator looking thing inside)
Mrcjolsen
I did it and it was easy. I may even take it out and vacuum the hole as suggested.
BTW, a bicycle spoke makes a great tool to pull out the old filter.
Rogue One
2022 Honda Pilot SE
Mrcjolsen wrote:I did it and it was easy. I may even take it out and vacuum the hole as suggested.
OMG! Thats ... GENIUS!!! Oh, wait, haven't got an old bike rim. I know, I'll use a wire coat hanger. Opps, won't work as they're all plastic. :ohno:
Return to “Rogue Forum”
