Is it total BS?Stock Internals 528whp??? (video)
GODCHSR
Car: 1996 Nissan 240sx
Someone make sense of this for me...http://www.youtube.com/watch?v...lated
Is it BS? I thought our stock block couldn't handle it?
James@CI
Car: 89 Nissan 240sx with SR20DET
I am going to have to throw the flag on this one lol
koukiFC
Car: 11 Chrysler 200(dd)
88 Rx7(ls swap project)
91 s13(ka-t round 2 project)
its all possible with the right tune,turbo, and psi. how long it lasts is another story.
kouki_hmongster
Car: Want 97 kouki
I dont know this car and dont know how long it will last with this power.. but i know that it's possible. It's all in the tune. Cory's stock internal ka-t did up to 400+whp around 20psi so i dont see why this isnt possible.
GODCHSR
It should be noted that the video is from 2006... I was also hoping someone had actually seen it before or knew who it was.
2FourTee
Car: 96 240sx - Supercharged ka24de
James@CI wrote: I am going to have to throw the flag on this one lol
It's been done before. The motor obviously won't last long at that power level. But I'm pretty sure that video is legit. http://www.ka-t.org/forums/viewtopic.php?t=30526
Modified by 2FourTee at 2:34 PM 8/28/2009
sunnys14
Car: S14
This video is old and is real.
James@CI
O i know it can be done and but it will not last long at all though.
hannibal
Car: Red Line to Glenmont
sunnys14 wrote:This video is old and is real.
Its legit as far as I know. That guy is a member of NICO. His username is "Jeff Taylor". After that KA-T, he built a VH45DET with 450whp at 6psi. The guy is good...
GODCHSR
sweet... sheds a lot of hope on the KA-T higher power build for me!
WDRacing
If he tore the motor down after that run I bet one or two of the rods was slightly bent. AMS was tuning one of their cars, Chris's IIRC and they bent rods and just over 500whp.
I'd say 450 is the highest I'd go without new rods. I've put a rod through the block already...ruins the whole damn motor vs just swapping a cracked piston and honing the cylinder.
BoostedSR240sx
its possible
i just want to know how long it lasted
hannibal
It lasted til he pulled it out for a VH-T.
I doubt he drove it around at that power level everyday...
fast_97_240sx
Car: 1997 240sx SE suspension mods only slow but it starts
Its real, the motor was purchased for less than $200 and had god knows how many miles. He had been driving the car on around 400whp for over a year then upped it that night. The car made at least 2 separate trips to Bristol motor speedway after that (maybe more) on crappy tires went very low 11's. The last night it was @ the track he said something felt funny~ tore it down after and had 2 bent rods (it was still running quite well @ that point). I was in the dyno room the night the video was made and the numbers are spot on. Tune was done by Jeff w/Scott Onishi (yellowmunsontunning) watching over. And it was his DD at the time, drove it aprox 15miles to/from work everyday. We all worked together @ the time.
GODCHSR
And THAT is what I call evidence.
You were in the actual room?You know the guy? Sounds like friends at least.
Cool
When he ran the 1s do you know how much boost he was pushing?
fast_97_240sx
GODCHSR wrote:And THAT is what I call evidence.
Cool
Yes in the dyno room @ Ride Revolution we all worked there at the time.
I'm thinking the charger was holding 30psi and maybe spiking a little above.
GODCHSR
Those really must have been some crappy tires for sure.
At 30psi I am thinking 10s should have been a reality.
GODCHSR
Is there anything official for stock KA block records?
I think this is probably the record for power but 1/4 mile drag???
Anyone seen a faster 1/4 mile time on stock block?
WDRacing
Ivan has run 9's at 150 with his AMS built S14.
http://www.youtube.com/watch?v...=fvwp
Thats just one of the runs...but it's the best video IMO.
GODCHSR
Built motor...I wonder what the stock motor 'record' is?
KFL
Car: S14
there's dps 7s s13 kat, not sure if video was posted already.
WDRacing
Dunno what the stock block record is...would be cool to have though.
hannibal
Its gotta be Jeff...
And Brian, you called it on the rods.
GODCHSR
Well unless it's 'recorded' somehow then it's not a record.
Who's Jeff? What did he run? Was his block/head stock?
hannibal
See first link. The owner's name is Jeff...
GODCHSR
LOL seriously I'm retarded...
If anyone knows him, try and contact him to find out what he ran in the 1/4 mile.
I'm not sure I count his run anyway since his compression was not stock (He used a Cometic)
GODCHSR
Also did he modify the head AT ALL?
fast_97_240sx
GODCHSR wrote:Also did he modify the head AT ALL?
NO only mod to the long-block assembly was a head gasket. Only other mods what was bolted to it ie: turbo manifold injectors etc...
Sorry I cant remember/or find exact time/speed car ran
fast_97_240sx
oops
