everpresentnoob »
https://forums.nicoclub.com/everpresentnoob-u268012.html
Wed Aug 02, 2017 3:48 pm
So my 1990 NA z has been giving me issues for the last couple months. basically its undriveable. Randomly while driving it will start hesitating, bucking surging trying to die. I have gone through the Ignition system. New working PTU, checked all coils chased wiring. All seems good. CHecked fuel system, new filter, confirmed fuel pump is delivering proper pressure. Checked all injectors. removed CAS, opened and cleaned it. car will run fine for a while then BAM back to the same old thing. I had over 300 trouble free miles last weekend, then monday morning at 0400 when I tried to go to work in it I made it two miles down the road and it started acting up. Took 20 mins to get to the next exit and then the three miles back to my house. if I gave it decent throttle it would basically not do anything, nothing was firing. I found that if I just barely touched the throttle, I could slowly drive it.
It has been suggested to look at the IACV. So yesterday I pulled it off. it was black inside, but the two pistons on the electric solenoids that I cant remember the names of were fairly clean and totally free moving. I cleaned it out any way. put it in an ultrasonic cleaner (Just the housing, all electrics were removed) for an hour and it was totally clean, as in the entire inside was totally shiny silver aluminum. put it back on today and reset my idle. Unhook the yellow plug, turn the brass screw under it until idle is at 650 then plug back in. Idle settled at around 800ish and was good and steady.
Then I checked my TPS. I had replaced it early on in this entire debacle and thought I had it set right. Hard idle switch showing continuity with throttle closed, no continuity as soon as I opened the throttle. TPS set to show .44 volts throttle closed and 5volts at full throttle. when I checked it today the hard idle was not set properly and the tps was going from .44 to 3.8v... played around with it for a bit but could not get full throttle to show more than 4.3, and that was with the tps totally rotated up. so that everything was out of spec. got it back to best I could do, Hard idle properly set, tps at .44 closed 3.8 full throttle, and fired up the car. Idle was sitting at 2000 rpm!!
I double checked everything I had messed with but couldnt find anything wrong. If I unplug the yellow plug on the IACV my idle drops back to where it should be, but once I plug it back in the idle jumps to 1800-2000 rpm again.
Does anyone have any ideas? Im about at my wits end with this car. I love driving it, but this is getting frustrating with it randomly being craptastic, now this odd idle issue...
