matt240det »
https://forums.nicoclub.com/matt240det-u909.html
Tue Aug 09, 2005 6:58 pm
well the fronts will wear quicker than the rears, check the outside pad wear in comparison to the inside pad, at each corner. check the bolts that hold the actual caliper to the bracket, basically the first bolts you take off when replacing the pads, there should be two per caliper, i belive they are 14mm, also do you have any brake pulsation that started when this happened? i.e. are the rotors getting extremly hot? also make sure your e-brake is actually releasing when you put it off
