Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Sat Jan 07, 2006 9:59 am
My opinion is that doing things improperly in relation to car dynamics is ab ad, bad idea. Cutting studs is bad, because the begning of the thread will be screwed, and you'll negate the benefit of the longer stud in the first place (better thread engagement with a higher 'pad' wheel). SPacres are just..god...dumb. Search around fot this. Myself , smothSR, C-kwick and anthony(dori-dori) had an in depth discussion about this a while ago..
conclusion? Buy the correct wheels for your car, don't band-aide anything.
Also, on the 30 degrees of body roll, etc thing.
Feeling like crap and actually influenceing the handling dynamics of a car are different things. Likewise, -3 deg. of camber isn't helping anyone unless you've actually taken pyrometer reading after a hard-road coarse run and determined that your tires/suspemsion are rolling over the tire THAT badly (which I seriously doubt), a suspension needs compression/travel in order to grip the road, period...otherwise you slide around on every little bump.
Also, drifintg or any other 'racing' on spacers is bad due to the ammount of stress they will see, and you're alsoreducing your effective wheel rate by running them, and ahving TWO sammiched together is doubly bad, because the pad can slip in yet another location (3!!!!) under stress, and can cause problems....
I'm locking this thread. It's a rediculous discussion to begin with.
ALso, I, nor AZ are NISMO's "legal" end, we're here to try and prevent people from doing stupid things that could possibly endanger themselves or their cars, while still providing help and solid advice when possible. Simple as that.
-Chet
