r34 gtr »
https://forums.nicoclub.com/r34-gtr-u3863.html
Tue Oct 09, 2007 4:02 pm
Youve got a 240sx with a CA18DET and need to change the water pump? Youll need to remove the upper and lower timing cover, water pump pulley, and crank pulley. The bolts holding on the upper timing cover are 4mm allen (i think) and the bolts on the lower cover are 8mm. You will probably have to remove the timing belt and then re-time the engine afterwards. Its probably an hour, hour and a half job, nothing too tough. Youll need a water pump from an 87 s12 200sx with a ca18et.
If youve got a stock 240sx with a ka24 I will be glad to have your thread moved to the appropriate forum.
Last, welcome to NICO!
