is it possible to use a clutch disc from any RB motor?
yourmomsrps13
Car: Drifting ruined my life since 03' 240sx CA18DET
I was told that i can use the clutch disc from a RB engine like a R32 and R33. i need to verify before i spend $ on something i cant use. also what do you guys think of a nismo bronze 9 puck sprung disc with exedy pressure plate for daily and drift?thanks
PulsarDet
Car: Nissan pulsar 88 or exa with DEt
Why don't use a custom clutch instead of using one that may not fit, I did order a custom one for my pulsar. For 400$ bux Canadian I had a 4 puck 450 hp rated clutch and 500 lbs of torque pressure plate. Just need to send the old clutch and pressure plate for model.
yourmomsrps13
because my PP is brand new and the disc is half of what you paid, for a bronze 9 puck sprung hub oh and its NISMO
CA19DET
i sold my old ctuch set up to a guy using a RB transmission, so i think once it sa 225mm or smaller disk and the same spline (as the RB and CA are) and once the disk material coverts the cover/presureplate contact surface, you are golden, so check the diameter of the RB disk, i am 90% sure teh disk alone will work on a CA cover/plate
and the NISMO and EXEDY covers i think are the same and are available in 750kg, 900kg and 1100kg clamping force...
