Qxxx4 wrote:I never do see an oil stain on my driveway, but i guess i have a small leak somewhere, I know theres a skidplate under the motor, so that means i wont be able to see an oil leak on the floor right?
What I usually do if I want to check something on the underside of the vehicle is take it to the quicklube place when thay are not busy and ask to walk under the vehicle. I've been changing oil at that shop for years so they always do that for me for free. Take a flashlight and check the top of the skid plate for oil and the quicklube mechanic might give you an idea of which gasket it's leaking from.
Another way is go to Canadian Tire, buy a couple of vehicle ramps and go under the truck yourself at home.
If there is no leak then maybe you have another problem.
