frapjap »
https://forums.nicoclub.com/frapjap-u17700.html
Thu Jan 30, 2014 9:32 am
I'd try to be more helpful, but all of the photos of your engine bay I see on an image search are of the stupid engine cover.
Looks like it will come down to checking it out yourself to see if you can maneuver a set of pliers, vice grips, or Dremell in there (to cut a groove for a flat head screw driver) between either the radiator or fire wall to see if you can turn the stud at all. The best bet is probably removing the actual manifold to get really good access or clearance to turn what is left of the stud. Granted, you don't have the time to do it yourself, but maybe if you can see that it is feasible, you can tell a mechanic specifically what is wrong and maybe they'll just remove the exhaust, the manifold, and then go to work getting that broken bad boy out of there.
