jedgington »
https://forums.nicoclub.com/jedgington-u72514.html
Sun May 29, 2011 3:52 pm
Sorry it has taken me a while to respond to this post. I finally took at look at this today. I thought the rattling was coming from the motor itself or a stripped gear or something like that. After doing all of this, though, I couldn't find what was wrong and ended up putting it all back together. On top of that, I realized I obtained the motor for the LEFT light and my problem is with the RIGHT one. Maybe the parts are the same, maybe not, I didn't take the chance. Hopefully, someone else gives this a try and can figure out what to do to fix the problem.
If you look at the back side of the headlight assembly, the up-down motor and gear assembly is inside a squarish black box. It will have either an "L" or "R" in white lettering, depending on which side of the car it's on. It might be a little hard to see on the right side since there is a fuse box or something in the way. This little box is really easy to get off the headlight assembly once you remove the front inner fender (I think the service manual calls it a fender protector)...whatever it is called, it is the black curved plastic piece at the front of the wheel well.
NOTE: from this point on, continue at your own risk. I'm not a technician, nor do I warrant what I say below. It is quite possible that you will irreversably mess up your headlights.
You need to take out two small screws that connect a geared shaft to the blue plastic gear on the back of this black box. That is easy to do through the wheel well. Then, you need to turn either the blue nut or the black gear to which it is attached so the black gear turns counterclockwise. This will loosen a screw that ties into the mechanism that aims the light up and down. Keep turning, it took about 30 complete revolutions to get mine loose. Then, grasp the box and turn the whole thing about 1/8 turn counterclockwise and it will disengage from the headlamp assembly and pull out. if it doesn't pull out easy, try further loosening the aforementioned screw.
Now comes the fun part. CAREFULLY loosen the cover from the black box by CAREFULLY prying on the tabs. I managed to break one off of my junk part during the process, so go easy. Once you get the cover off, you'll see the motor, worm gear, and actuating gear that pulls on the screw we loosened above. Be very careful when disassembling this, as the whole assembly is delicate and also contains a sensor that tells the car where the light is aimed.
To put it back together, reverse the procedure. Before you reinstall the remote shaft, though, you should adjust the aim of the headlights by turning the blue nut.
Good luck to anyone who gives this a shot. If you're successful, please post a reply to this thread.
