Is it possible to change normal key ignition to keyless ignition?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
jandro04
So i bought a Nissan Tiida (Versa) 2007 a week ago and it came with a normal key and then i saw that there is a version of the car that you can start it with no key, it has a smart key so you can start it with no key.
I wanted to know if its possible to change my normal key ignition to that fancy keyless ignition?
Thanks!
Codelicious
Car: 1989 Nissan 240SX
I'm sure it's possible but it's probably not an easy job to do considering the buttons on the outside and the sensors that it probably has to recognize that the ikey is actually in the car.
jandro04
So where can i get this job done? and do you think it would be too expensive?
McLeod1981
Car: Brilliant Silver 2009 Versa 1.8S w/ power-package, cruise control
bump
jandro04 wrote:So where can i get this job done? and do you think it would be too expensive?
price out 1x bcm , driver's i-key door handle rear trunk/hatch i-key door handle, i-key module, and labor looking at aprox 2-4k us.
dougiefresh
Car: Versa
I dunno if this may help, but I saw this: Keyless Ignition & Push Button Starter....
Return to “Versa Technical Discussions”
