Encryptshun »
https://forums.nicoclub.com/encryptshun-u67236.html
Tue Jun 26, 2007 7:41 am
Not only will all the turbo plumbing and exhaust manifold need fabbing, but I'm skeptical as to if turbox2 is going to produce the effect you think it will. If you're going to run that setup, you'll need a bigger fuel pump, injectors, fuel rail (or double inlet the stock rail), and intake plenum; you'll need to reflash your ECU and tune the **** out of the car. Otherwise you'll just be running lean and damaging your engine.
But give it a try -- and be sure to come back to post a how-to with pics! Good luck!
