Is it possible??
paemt6220
Car: 1997 Maxima SE 5MT - MODDED
In the near future(3-5 months) I am going to be turboing my KA24DE. I am working on the suspention, brakes and "feet" right now. I want to know if it is possible to make around 350rwhp with stock internals and not break anything. I was going to build the motor but I keep hearing that it can be done without building the motor.
I don't have the money to do it twice, so I want to make sure that the motor will hold that power.
Any input will help
Thanks
Chad
gore
Car: 93 240SX hatch (ca18det)
you'd be seriously pushing your luck, best bet is to buy a ka24de block from someon doing an sr swap, and build that one. it will save you down time and such.
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
Ask WD I think it is entirely possible. Just tune it right
turtl631
Car: S14
Its possible but the margin for error is small. You better really know what you're doing, run 93 octane, take no shortcuts, etc. I plan to do the same thing eventually. I may implement alcohol injection to reduce chances of detonation above 12 psi or so. As they said, tuning will be key.
Jookmasta
tuning is ur friend as u are really nearing the limit. U will most likely need an ecu or standalone as u would be hard pressed to run close to the limit with an safc. Meth/alky injection would really come into play since detonation is now ur major concern. But as said earlier, it can be done with proper tuning.
jab11185
Car: 1992 Nissan 240sx
it's totally possibly but like turtl631 said u have a small margin for error
do a compression test and a full tune-up if you don't plan on doing a full build....
i had my the head machined, pressure checked, block honed and checked for cracks, crank, pistons, and rods balenced for $435...so as long as ur not against some assembly i'd suggest a spare KA and be sure that everythings done right
so it's not THAT expensive...but be ready to shell out more money and wait a lot longer than you expect
