Is it ok to use overdrive 1 2 3?
infinitiboyj30
Car: 1993 infiniti j30
i miss drivin stick so i was wondering will using the 1 2 3 on the j30 ok? or will it be bad for the transmission? will it cause my trans fluid to get dirty faster?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Its completely OK to do it because all your doing is telling the TCU (Transmission Control Unit) when you want to shift.
If you don't drive hard and change the fluid regularly then it wont' "get dirty faster".
driverdriver
Car: NICO's longtime resident Canuck!!!
Personally I would only use the lower gears if I'm climbing a steep hill, towing or in deep snow. You got remember your J is an old car, If it hasn't been driven that way for most of its life (shifting 1, 2, 3) there is a high chance you can break something in the transmission.
#1 Sailor Scout
Car: 2007 Honda Civic LX
Infiniti J30 fan
infinitiboyj30 wrote:i miss drivin stick so i was wondering will using the 1 2 3 on the j30 ok? or will it be bad for the transmission? will it cause my trans fluid to get dirty faster?
I agree with Paul Wall & driverdriver. But don't expect any performance gains out of it.
yodawill2000
Car: 94 Infiniti J30
I leave mine in first for my once a week redline carbon removal session. Redline and lift about 6 or 7 times.Other than that she stays in D.
