is it ok to use different size charge pipes?
AN89HATCH
I am making a home made turbo set up, and Ive decided to just use an sr intercooler. i want to buy a cheep intake off ebay to get the pipe from the intake manifold, over to the inter cooler area, but all the intakes are around 3 inches. Is it ok to go from a 2 inch charge pipe to a 3 inch charge pie? or will this cause some problems?
andrave
Car: 1989 Nissan 240SX Coupe
it will be fine.
daniel240
Car: cars/motocross
like he said, it doesnt matter, as long as its all hooked together w/ no leaks. i have 2.5 from turbo to ic, and 3'' from ic to TB and it works good.
AN89HATCH
thanks!:)
NX95240
Car: my KA-(sc61)
daniel , u have any pic on the piping hot and cold side? thank
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
daniel240 wrote:i have 2.5 from turbo to ic, and 3'' from ic to TB and it works good.
what’s your pressure drop?
daniel240
Car: cars/motocross
what exactly do you mean by pressure drop?
huguetpj
Car: 93 KAT Coupe
Pressure at compressor outlet - Pressure at manifold = pressure drop acrros piping and cooler
daniel240
Car: cars/motocross
im not sure, i have not tested that.
Checkered-Member
huguetpj wrote:Pressure at compressor outlet - Pressure at manifold = pressure drop acrros piping and cooler
I was thinking more like:Pressure at compressor outlet - pressure at TB = Pressure Drop
huguetpj
Car: 93 KAT Coupe
Checkered-Member wrote:I was thinking more like:Pressure at compressor outlet - pressure at TB = Pressure Drop
Once the throttle plate opens TB press = Manifold press, and that's the pressure drop that's most important... at WOT :pface
