Is it ok to change rear tires thats 235 50 17 to 255 45 17?
Nissan 350z / Nissan 370z general community discussion forum
o4350z
I will keep the front to the factory specs but i was wondering if i can change my back tires. i will go from 235 50 17 to 255 45 17. will this jeapordize my safety or performance?
BlackSmoke
Car: 2007 350z Grand Touring
Yes if your rim width is 8.5 inches. The diameter on the factories are 26.9 inches and the 255/45/17 will be 25.9 inches. Just a bit lower profile but should be just fine.
inline350
Car: 350z
I wanna do the same let me know how this worked out. And if you did what tires did you use?Thanks I would really appreciate it.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
When in doubt, use the tire size calculator:
http://www.1010tires.com/TireSizeCalculator.asp
C-Kwik
i would really try to keep the tire diameter ratio between the front and rear tires as close to the OE specs as possible to avoid issues with the VDC.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the problem I see is the extra width, a 255 wide should be on about a 9" wide wheel, a 235 should be on about an 8" wide wheel, you have a bit of wiggle room and some manufacturers will vary but in general you want wider tires you'll need wider wheels to accompdate them
Return to “350z / 370z Discussion”
