Is it normal to smell gas under the hood?
S13ChucKAT
Car: asd
Yeah. i was inspecting my car, after 2 monhts, of still having a bad idle.. and i smell gas when i pop the hood.. at first i must not have paid attention.. but now i can smell it.. it smell stronger as i go twards the firewall.. im thinking maybe an injector seal has gone bad. But, i dont see any gas anywhere..
silkk
Car: 94 B13
89 S13
07 S2000
doesn't fuel turn to vapor?
check the bottom of your hood and see if there are any thingies on the underside
S13ChucKAT
Car: asd
any thingies?..
im assuming a fuel injector seal is bad or something.
240DRFT
that started to happen to me too, and it turned out to be a few of the injector seals, so i replaced all of them
nab911
Car: 93 Nissan 240SX SE
Im sure youve done this, but check all the fuel lines and such for leaks/cracking. Also replace your fuel filter and pump to fix that idle problem.
ricebike
2002 Quest
2005 Altima
replacing the pump is kinda extreme... filter & new fuel injection <not regular fuel> hoses w/ clamps would do just fine, along w/ what others said to be the fuel injectors/seals...
I had a crack on one injector & bad seals on another; but changed all of them to be safe.
