youngdustin wrote:I understand the purpose of engine braking, but to me, it seems like it's quite a bit of wear/tear to put on the engine when I can use the brakes that are much, much cheaper to replace. Now, I'll be happy to do some engine braking if I think I'm using the brakes too much so as to not burn them out.
Is there anyone out there that can give some technical/expert advice on the matter? I marvel at people that engine brake when coming to a normal stop sign/light.
Engine wear from engine braking at the mid to low RPM range (under 4,000) doesn't introduce any significant amount of wear and tear, it is a common misconception for people who think that it does--the amount of friction involved is absolutely minimal. Any usage of brakes wears them down faster, because its function is based on friction. The reason why engine braking works is because on modern fuel injection cars, any time you lift fully off the throttle and the engine speed range is above idle fuel delivery limit, the engine becomes essentially an air pump and the result is an engine brake effect (zero delivery of fuel and air--full throttle cut-off). The amount of lubrication on the engine renders wear and tear from engine braking virtually nil, as the oil pump continues running any time the engine is spinning, regardless of fuel delivery. Leaving the gearing high (i.e. running the engine low RPM) and braking consequentially uses up your brakes, is a risk of excessively heating the brakes (on long, steep and/or high speed downhill grades) and uses more fuel if the engine gets down below the idle fuel cut-off range (once it goes below that mark, typically ~1400RPM) because now it has to feed in idle holding fuel and air.
As far as engine braking to a light, the only reasonable time to do that is if you're going a short distance between lights, and the next light stays red a while after the previous one turned green. I know this happens often here in Westchester, where at best I get into 2nd gear out of a green light before coming up to the next light and it is still red (crappy timing). Downshifting to engine brake to a light is stupid; in that situation, any intelligent driver has a foot over the brake pedal anyway, and should just use them. A red light implies you should be going fairly low speed already, and at those speeds, there isn't a significant amount of brake wear for applying them, so it is the best way to control your speed. In fact, on the vast majority of automatic cars, engine braking to a light is completely lacking control because the torque converter is not going to be locked and only a mere fraction of engine braking torque passes to the actual wheels. Only on cars with clutches and not torque converters (real manuals with a clutch pedal or multiclutch automated manuals) make any sense to engine brake into red lights, and even then, it's really ridiculous to downshift from a high gear into a low gear only to engine brake; more than likely, they anticipate that the light will change to green very soon and would rather be in the correct gear beforehand; as a driver with years of metropolitan stick shift driving experience, I know when that light is going to turn green soon, and I know I'd rather be in 2nd gear before it does, because I'm going to have to downshift anyway, and it would be wasted time shifting after the fact. But then again, I always did a proper throttle blip on ALL downshifts, braking or not (heel & toe, very very often).
Let me know in case my explanations don't make sense to you...
-Ed
Modified by EddNog at 11:04 PM 11/11/2008
