is it my water pump?
asher4857
Car: '89 240SX Fastback
So the other night I was driving with my girlfriend to her house when all the sudden my incar thermo starts reading really hot.. basically H.. so when I got there, I checked my radiator and overflow and it wasnt empty, but I had to add half a thing of coolant.
When we had finished my swap I knew i had a small leak but I didnt think it was that bad. I couldnt see huge puddles of the stuff under my car.. just little drops..
well today I was going to Anumerics hosue and all th sudden it started reading hot again.. so i pulled into the gas station, checked under the car.. and i saw a huge puddle.. within seconds of pulling up.. i had a huge puddle under my car. I looked in the engine bay and saw it leaking from around middle on the intake side. Is my water pump going bad? I added more coolant and drove home so Im just waiting to here whats up
ccasey645
Car: 1989 240sx ca18det swap
asher4857 wrote: I looked in the engine bay and saw it leaking from around middle on the intake side. Is my water pump going bad? I added more coolant and drove home so Im just waiting to here whats up
middle on intake side? middle of block? there are heater hoses that run right by the intake so either that or a freeze plug. snag a coolant system pressure tester and you'll find out real quick.
asher4857
alright, thanks man. Im not sure where exactly it was coming from, I just saw it dripping but couldnt get the angle of where exactly
ccasey645
reminds me of my old 99 dsm had port and polished head and my lower radiator aquired a slice in it. My coolant temp went half way to h and cracked my head in an exhaust runner
ccasey645
yea those hoses can be a pain Ive heard some people taking off the top half of their intake manifolds to get to them but thats probibly it I would think someone correct me if im wrong
asher4857
hahaha.. you arent making me feel any better.. lol well.. the car will not be driven until the problem is fixed soo.. yea
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
Probably a heater hose, or the turbo water supply hose. Could be the oil cooler water hoses.
Get a bright light under there while it's hot to find where it's squirting out.
rico05
Car: 1992 RMS13 w/ CA18DET
Good luck. I seriously thrashed my hands changing all those on the car, lol. I wish I had done it before the swap...
ccasey645
lol im not tryin to be too pesimistic I thought id blown my head gasket because coolant smellin smoke was comin out my exhaust turns out it just cracked in my exhaust runner in my head and was traveling out my exhaust system and hittin my cat and burning
rico05
Without puncuation and other nicities of the modern english language, I had a hard time figuring out what you just said....
Did you crack the head?
ccasey645
Yes.
asher4857
well, anumeric came over today and we took a look at what the problem was. turned out it was a heater house near the back that had two bursts in it. Taking it off was pretty easy, went to Lowes, grabbed a new one, installed it. Everythings all good now! Thanks for the help guys!
float_6969
The CA is pretty stout, and a lot of people on here have overheated them numerous times w/o a noticable problem, but keep in mind this is still a cast iron block, and aluminum head. The dissimilar metals expand and contract at different rates and you can very easily warp the head and not know it. I suspect the stock HG is very forgiving.
SeVa-S13
Car: '05 GTO 6spd
asher4857 wrote:well, anumeric came over today and we took a look at what the problem was. turned out it was a heater house near the back that had two bursts in it. Taking it off was pretty easy, went to Lowes, grabbed a new one, installed it. Everythings all good now! Thanks for the help guys!
lol Wei to the rescue.You shoulda been able to find that yerself.
asher4857
yea.. i didnt quite know where to look though, once we told me, and he spotted it, the only hard part was unbolting the little clamp that was holding the other end down hidden somewhere..
capowered240
Car: 90 240sx
I've also got a water pump question. The car is not drivable yet, I'm doing some rewiring right now, but anyway everytime I go to work on the car (its at a friends shop right now) I check oil and water before I start it up. I have to put water in it everytime I go out there to work on it. I'm using the de water pump. Doesn't smoke when I start it up. Got the 195 degree thermostat.
ccasey645
Might be like my dsm. I was rebuilding her because of a snapped timing belt and put crower cams, titanium valve springs/retainers, and 3 angle valve seats along with the port and polished head. It took a while because of waiting on parts, etc so the car sat for a while with no head or pistons, oil, water, etc in the car, just the bare block, crank, and transmission. After putting it all back together a week later my water pump blew from sitting without coolant for so long. The seal went which sucked b/c it was run on my timing which ment I had to re time my motor, take a motor mount out, a bunch of stuff. Anyway point being when they go, they go in force normally. I had leaked out 2 gallons of coolant in like 3 minutes. Quickest way to know exactly is to rent a coolant pressure tester from shucks/checkers, napa, autozone, whatever or find someone with one (they cost upwards of $150 new), slap it on there and look for the water comin out! As for the de water pump im not sure Water pump 21010-V5528 (CA18) until 8/90Water pump 21010-V5529 (CA18) from 8/90Water pump 21010-52F00 (SR20 all)Use a CA18ET waterpump from an S12Thermostat 21200-V0201 (CA18 all) 82.0 CThermostat 21200-V0206 (CA18 all) 88.0 CThermostat 21200-53J00 (SR20 all) parts list is stickyed on the top of teh ca fourm
capowered240
Car: 90 240sx
Alright, I'm just going to change out the water pump. I'll get the ET water pump this time. I can get it at advance auto parts for like $37.
