is it easy to put vg30dett auto
j30raceking4
Car: J30 T
i need to know if it is easy to do it with auto cause my little brother wants me to install it can anyone give me tips before i put it in i have ECU and wire harness zer...d=178#http://forums.nicoclub.com/zer...d=178#
95-J30tt
Car: 95 Infiniti J30tt (Twin Turbo)
you can find some info on the swap under "Project Q-ship Progress" in this forum, i have not yet finished the swap, i hope that this can help you
you wont need the TT harness, you will have to use the harness that is in your J30 engine, including engine and ECU harnesses, and you will have to either change your drive shaft to fit the TT auto transmission, or use the auto transmission that is in the J30, it will mate with the TT engine without problems......
there is so much to mension, i think it is best if you check out the topic noted above, if you have any further questions, i'll be more than glad to help out
Defiant
Car: 1997 J30
What did you do to make your little brother so angry with you? It's probably about time he learned to turn wrenches for himself.
As for the job, it's easier to walk to France.
vishesh
Car: '95 Infiniti J30
Defiant wrote:What did you do to make your little brother so angry with you? It's probably about time he learned to turn wrenches for himself.
Agreed. I haven't done either myself (the swap or the walk to France), but from what other people say, it sounds like a real clusterf-ck. Looks like it is possible, but definitely clusterf-ckish.
