kevinis wrote:The mechanic is saying that the engine computer is gushing fuel into the #3 cylinder which is not burning (causing the cat smell) and is also saying the plug was fouled already after installing the new ones.
Unless the newer Q got a much more advanced ECU (and I don't think they did) the ECU is not able to control each injector's pulse width (how long they're open spraying fuel) independently. On my Q, and I suspect yours as well, the ECU can change the pulse width for a bank of injectors to compensate for readings it's getting from the O2 sensor on that bank.
Here is a TSB from Nissan on performing an injector leak-down test.
http://maxima.theowensfamily.com/tsb/NTB95-021.pdf A normal drop would be about 20 psi in two hours. If you have as big of a leak as it seems, you would probably see total loss of fuel pressure in 10 minutes or so. At least I assume the numbers would be similar for the Q. A more labor intensive test would be to pull the plenum and rails, and look for fuel squirting out around the lower injector o-ring when you turn the key on and the pump primes. Or if injector 3 is accessible without too much trouble, just pull it and put new O-rings on.
