Is it crank sens., tps, ...or the whole thing!!??
tek747
Car: 95 nissan 240
So ive checkedabout half the forum, and still puzzled!! MAF-good i repined the plug, timing ( because it seems to missfire, cleaned out distributor, etc..... there is just one thing that mine does...... it dont stall out on lights or when i park the car and needle doesnt act wacky anymore but it still put-puts after 3klicks!! BUT!.? IF i go easy on the throttle its ok to good (most of the time) If any one, can help me, then just maybe ill still have hair!!
180fan
Car: 89 fastback
ok so how about a clear description of the problem?
tek747
Car: 95 nissan 240
When i accel. normal, on 1st good2nd good all the way to red line!3rd- this is when i start having issues when the needle hits just about 3klicks (it statrts hesitating) like its either starving itself: not enough fuel, and it smells just alittle bit like gas as if it wher running rich. But id say 3500k to 4000 its like it wakes up and goes!!4th same, 5th sometimes!With all these symptoms concidered, i checked and fixed MAS plug it, wires were striped. Checked most of the vac. lines, and shows no cracks or rips. Checked groung with Ohm meter and it read 1.7 off and 0.0 when running at idle. Sometimes, it even gurgles or put-puts at 2100k like it wants to quit!
tek747
Car: 95 nissan 240
Oh yeah, and like i said before if i feather the gas just right through all the gears............. it dont do it! I think i just grew some white hairs over this!!
MysteryIncMan
Car: 1995 240sx SE
Just wondering if you have found a solution? My car seems to be doing the same thing and I am clueless.
tek747
Car: 95 nissan 240
Im going through the entire engine bay today and tommorrow, so hopefully i will have arespose by no later than wed afternoon!!! Hopefully sooner!!
180fan
Car: 89 fastback
I'd be suspicious of a messed up tps. It doesn't take long to check or to calibrate either so it shouldn't take long to do this.
tek747
Car: 95 nissan 240
TPS!? I thought of it a while ago and tossed it out the window- will check!
