First, here is the link to the guide on racebread.com
http://www.racebread.com/Docum...s.rtf
Second, I haven't checked the plugs, but I did check the ECU for codes. Got "21" and checked the ignition system (page EN-319) as it describes. Everything was fine until I made it to part C in checking the continuity between the power transistor plug (pins 2,3,4,5,6,E) and the ECU plug (pins 1,2,3,10,11,12,13,20). I don't have any continuity besides between ECU terminal 3 and power transistor plug terminal 3. Everything else came up negative for continuity. Does this mean that the wires between the power transistor and ECU are fried? Is that even possible?
And lastly, what could have happened because I thought for sure a fuse would blow before $hit really hit the fan and started frying things..
