Is It a ticking time bomb?
ShionS14
Car: 2003 Saab 9-3, 2005 Infiniti FX35
I was under the hood of my car earlier today while it was running and noticed a ticking sound coming from the cylinder hear. It sounded like something with the cams or valves. Now it didnt necessarily sound like something was wrong, but I had never noticed it before, what does it sound like to you guys?
MarkEmark
Car: fully-built '95 240sx KA-T
ShionS14 wrote:I was under the hood of my car earlier today while it was running and noticed a ticking sound coming from the cylinder hear. It sounded like something with the cams or valves. Now it didnt necessarily sound like something was wrong, but I had never noticed it before, what does it sound like to you guys?
Search.
There have been DOZENS of threads on this. It's your upper timing chain slapping against the chain guard. Nissan eliminated this guard with their OEM timing chain kits. Get rid of the guard and/or replace your tensioners and it should get rid of the sound.
And also, you're in the wrong forum, this should be a 240sx technical question, this has nothing to do with being turbocharged.
EazyBreazy
change the oil thats what i did and my ticking went away....if that doesnt work its probably time to open the front cover and take off the timing chain guides
ShionS14
sorry guys i know what a timing chain sounds like when its ticking and thats not it. this sounds more like valve lash, which wouldnt make sense to me. sorry for posting here, this is the only forum i really like to go into and i didnt even think about it when i opened this thread.
C-Kwik
It could also be the fuel injectors. The OEM ones are fairly loud. The KA24DE valvetrain is quite durable and is not as prone to valve lash problems as other motors are.
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
Also could be your lifters.. that is a clicking sound.. Check your oil level... or it could just be the injectors doing their thing
HolyShiznit
Car: Working on my car
Lifters? The KADE doesn't have lifters does it?
C-Kwik
The KA does have lifters. It does not have rockers though. It does seem rather backwards, but lifters refers to valve lift. So technically all valved motors have lifters.
turbo_lover
Car: 240sx
adjust your valves. my brother had this problem with his Turbo LS Civic Hatch. Good Luck man.
