szh »
https://forums.nicoclub.com/szh-u149.html
Tue Oct 21, 2003 2:34 pm
Hi, all!
A question (or more) about one of my paranoid practices.
Whenever I buy a new car, after the break-in period (which has varied between 1k to 2k miles), I replace all the fluids associated with gears and "things in motion rubbing over surfaces". This typically means that I take the car in and have them replace the engine oil, oil filter, differential gear oil, power steering fluid and transmission fluid. I have done this to every new car I bought.
My crazy rationale is that moving parts and machined parts (even if micro-machined as in the case of the new Infiniti engines) will have some metal surface smoothing/burnishing and "burr removal" during the first few thousand miles of operation. This material will typically end up in the oils and fluids, so I change them (I don't do the engine coolant or brake fluid since it is not dealing with parts rubbing against each other).
Before I do this to my new M45, I thought I would ask the experts here on the forum. Is the above overkill? Would you do it? I am particularly concerned that maybe I should not do this to the transmission fluid - supposedly, these new transmissions (in the Q, M and G) are very well sealed and the less I do to open them, the better.
What do you all think?
Z
