Is compressor surge bad for your turbo on low boost?
adrianfromthecastle
Car: 1992 Nissan 240sx
I'm talking about low, like 0.2 or 0.1 bar. I have the Greddy RS bov, and I could adjust the spring to make it softer, but I'm not gonna do it unless I should...
nwmrkt
Car: S13
why not, just adjust it man. No surge is best. Do you like the sound lol?
Geno750
adrians_s13 wrote:I'm talking about low, like 0.2 or 0.1 bar. I have the Greddy RS bov, and I could adjust the spring to make it softer, but I'm not gonna do it unless I should...
You will be fine with surge at that small amount of boost, I wouldn't worry about it.
AE86Gio15
Car: s13
theres a lot of drifters out there running no bov at all and i have yet to hear of a turbo being damaged.
adrianfromthecastle
nwmrkt wrote:why not, just adjust it man. No surge is best. Do you like the sound lol?
nah cuz if I make it softer, I'm afraid I'll stall more.
AE86Gio15 wrote:theres a lot of drifters out there running no bov at all and i have yet to hear of a turbo being damaged.
that cuz they still have a stock recirculation valve
nwmrkt
Car: S13
adrians_s13 wrote:nah cuz if I make it softer, I'm afraid I'll stall more.
ic coolio.
AE86Gio15
Car: s13
nope not even the stock recirculation valve
jlee29
Car: S13/15 6.0 Chevy V8 :-P
Mazda Protege Kicker L7 15" (Beater)
i agree
jubee
Car: 92hs13
On a Stock T25 turbo compressor serge is gonna end its life quickly but on bigger turbos you really dont have to worrie.
AE86Gio15
Car: s13
not from what i have seen.
adrianfromthecastle
AE86Gio15 wrote:not from what i have seen.
that's insane dude... I've never heard such a thing
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
I'm relatively new to turbos (as you know) but everything I've read or heard says that any compressor surge=not good. My 0.01 cents
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
At low turbine speeds it isn't a problem, but when you're running right in the efficiency range it isn't good at all, on ANY turbo.
At low boost (low turbine/compressor speed, probably around 1/4 to 1/3 the normal boost) it isn't going to cause any problems at all, but if you're getting surge at higher boost, that isn't good.
Edit:Although, no compressor surge would be ideal.
Logan76
Car: Junk
Compressor surge is your turbo spinning backwards in a way, do you really think thats good for your vehicle? ITS NEVER GOOD! I dont care what anyone above me said, Running no BOV at all is ****ing terrible, at .1bar i doubt youll have trouble, but if you dont run a BOV, your dumb.
DriftReadyS13
Car: 92 s13 w/ sr20
get reid of the surge and you wont have to worry. it was a big thing on my srt-4 . espescially high gear low rpm. but i dunno stalling isnt good for the car either . but what do i know
S3t0_S13
Car: Of Nothing But FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL
since i can lend no knowledgable information to this thread
and i cant find a decent pic of the N/A Logo
seto ftl
Seishuku
Compressor surge is a turbine stall, it's not spinning backwards.To spin it backwards, you would need one hell of a large volume of back-flowing air at low turbine speeds. And the only real way for that to happen, is with a very large turbo. Which still isn't very likely, IMO.
But like I said, a turbine stall at high speeds is very bad, and could actually spin the compressor wheel's lock nut off.
But you are right, no bypass valve is a bad idea, but then again, venting to atmosphere with MAFS based management is a bad idea, but people will still do it.Not saying that a lot of people run with out a BOV, but it's their car and their engine and they'll do what they want to it.
Logan76 wrote:Compressor surge is your turbo spinning backwards in a way, do you really think thats good for your vehicle? ITS NEVER GOOD! I dont care what anyone above me said, Running no BOV at all is ****ing terrible, at .1bar i doubt youll have trouble, but if you dont run a BOV, your dumb.
Logan76
Car: Junk
Yes, I never said to vent to the atmosphere, A recirculated BOV, is always your best bet unless your running blow through MAF's or a Map sensor, Ive always been a firm believer that BOV's to the atmosphere are rice, especially if its hurting your performance.
AE86Gio15
Car: s13
iirc some of the drift alliance members do not run bov's
Modified by AE86Gio15 at 4:12 AM 7/19/2007
