:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Mon Sep 08, 2003 11:25 am
Agreed.
You need velocity and volume from an N/A exhaust - Smaller piping keeps the exhaust gas velocity high and aids scavenging at high RPMs. But too small will choke it out up top and cause unneeded backpressure.
So you have to find a balance...and from my experience, any of the 60mm exhaust will do fine up to ~160rwhp. Past that, a 3"/75mm may add a little up top at the expense of a little low end, but isn't a necessity.
I'd actually say that 2.5" mandrel bent would be ideal...60mm is only 2.36".
And before someone asks about backpressure being "good" or "needed": Backpressure is a result, not a cause. Properly sized piping will add some amount of backpressure, and it's a necessary evil, but as little as possible is best, as long as you don't hurt velocity.
Ok, sorry for the rant...
Later - Brian
