rjyentsch21 »
https://forums.nicoclub.com/rjyentsch21-u66044.html
Sun May 18, 2008 2:43 pm
So...I finally worked all the of the demons out of my electrical system, and a new KA-T is on the road. Just using it for short hops to town and back until I trust it more (and until I get an exhaust on the SOB). Now that I'm running, I do have a few questiosn for the wise men around here:
I backfire upon throttle off decel...loud. It's usually only bad if I was running pretty hard before, but its always there just a little bit. I'm running open downpipe right now, so that sure as heck isn't helping, but my real question is this: is backfire dangerous? Once I get a muffler on there, I'm sure I can handle the noise, but can I actually hurt my 02 sensor, hot side of the turbo, or anything else from backfire?
How long should I give the engine as a "break in" period after rebuld? 500 miles? More? I'm trying to keep my foot...mostly...out of it until it's had some time to heal...
My set up is as follows:Rebuilt engine w/ 8.5:1 compression, forged rods, new gaskets, bearings, all clearances checked, etc. etc. Compression is where it should be on an unbroken in engine.Enthalpy tuned ECU (16 bit daughter board)50 lb. fuel injectors255 lph fuel pumpadjustable FPR (currently set to the stock ~43 psi)tubular manifoldT3/T04E turbocharger2.5" open downpipenarrowband O2 sensor and gaugeboost gaugeoil pressure guageaftermarket temp gaugeblow through stock MAF on the cold sideBlow off valve on the hot side (open)wastegaterelocated batterynew clutchone stage colder than stock plugs gapped to .035MSD coil
I'm running around 7lb boost at peak on 93 octane @ 15 degrees timing. My AFR's are decent on the narrowband, just a tiny bit rich under throttle. She pulls wonderfully and runs fine now what she's had a little bit of road time.
I'll try to post a picture or two after I get the engine cleaned tonight (sitting for three months while I was at school didn't help the appearance any).
