Is anyone using a G-FORCE ECU in the Q?
1qckser
Car: my wife, daughter, q45T,G20T,SE-R
Was trying to decide between the JWT ECU and the G-FORCE ECU, I was told by GFORCE that there ECU produces more mid range power than the JWT and is a better all around program except it does not remove the speedlimiter. :)
Q45tech
Go with the JWT ecu.....mid range power what does that mean?
There is nothing material to be gained below 3300 rpm no matter what you try.....spent 3 days on a dyno trying everything.We A/B ed everything and trimmed [+-15%] the JWT and stock ecu with a $11,000 prom extender from Techtom [courtesy of Nissan Racing back in 1994]. The only thing that worked was 106+ racing fuel and more advance.What most don't realize is the Consult will allow minute changes in timing/fuel while connected - just not permanent as the ecu reverts to the PROM upon disconnection.
The other problem is a chassis dyno is not real world as it is level and generally UNDERLOADS the Q due to the roller diameter and weight....... anything +- 5-10 HP is suspect!
We have installed over 25 JWT units and never had problems including a couple of Nitrous conversions.Absolutely the best bang for the buck!
1qckser
Thanks Tech, im going with the JWT:D
aaacomp
Car: Family, church, Computers, Cars
Glad to be Back..........:D
QShip
It took you long enough aaacomp :D
1qckser
Aaacomp, I gave ya a call about getting some stuff while my wife wasnt around, but now she is back:sad so I will call you again next week, Thanks.
