Is anyone running an Electric fan in a TT
NolimitZ32
Is anyone running and electric (puller) fan instead of the manual clutch fan? If so what fan and how does it stack up vs. the stock manual one?
evan_aggie
Car: 1994 300zx na t-top
I don't know much about this, but I had been reading a lot of people choose to go with the Flex Lite 210 I think....it is a dual fan setup and relatively cheap.
I was thinking about doing this to my NA to squeeze out every hp possible to the wheels rather than to all of these lossy rotating parts.
However, I'm not sure really what I'd be saving myself by removing the fan clutch and fan....a stretch would probably be 5 hp to a NA.
OUKNO
Car: 1990 Z32 NA, 1974 International Scout
I put a dual E-fan set up from a 97 Altima with the temp sensor I paid less than $100 all bought off ebay and it keeps my car running perfectly at all temps.And I'm sure there is a little HP gain but just cleaning up the engine bay is worth the money. Makes the UR pulleys look so much more pretty.
Z32TT
Car: 90' 300ZX TT
if your going to do this upgrade on a TT i recomend an upgraded thermostat. Nismo etc..
NolimitZ32
Thanks guys, I have a e-fan with a built on shroud off a volvo, not sure which volvo, but it fits perfectly over the TT rad. I had it wired to the pusher fan but have now realized that the pusher only comes on at 210 which is a bit too high for comfort so im looking at running a thermo unit w/ probe.
charlie0369
Car: 1995 300zxTT, 01 CLK 320, 02 Dodge Ram, 05 GSXR-1000, 03 GSXR-1000, 99 superjet, 96 waveblaster, 97
I bought one off ebay a while back, it's the square one with an adjustable thermo switch built in. 3000CFM...paid like $145 plus $15 shipping. Turns out it was the same fan some of our local speed shops were selling that they put on bigblock powerplants all the time. i kinda smiled when i saw a $299 price tag at my local shop. Brackets actually fit quite well for install and looks very clean and easy to wire up. It adds performance cause it takes a load off the belts and makes your waterpump last longer.
evan_aggie
I'm very tempted to go ahead and order a Flex-a-Lite 210/220 while I'm doing my 120k service and everything is out.
OUKNO
that's when I did mineperfect time to change it, you already have all the crap out of the wayI heard that Volvo one is the way to go as far as CFM's
evan_aggie
Z1 sells a fan intended for the NA, but they don't have the CFM specs.
I'm anxious about causing any overheating. Who else makes a setup that will fit in a 300zx?
I only know of flex-a-lite, but maybe the 2500 CFM isn't enough.
madmax3040
Car: 1993 300zx
Hey charlie0369 do you know what E-Fan your using. I'm looking for a setup myself and Im trying to get the most for my buck
300ZXttZMAN
madmax3040 wrote:Hey charlie0369 do you know what E-Fan your using. I'm looking for a setup myself and Im trying to get the most for my buck
Charlie hasn't been on in a number of years. I doubt he is going to reply. Have you ever heard of the Taurus SHO fan mod? I know a couple NA guys running that setup but I don't know of any TT's running it.
Fearspect
Car: 1990 Nissan 300zx TT 2+2
Z32TT wrote:if your going to do this upgrade on a TT i recomend an upgraded thermostat. Nismo etc..
The Nismo Thermostat provides no benefits for your car, and can in fact decrease performance. Save the money.
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
SHO fan should work well for a TT as well, provided there are no other cooling issues.
