Is any one using a Greddy Rebic??????
Nskylinerb-25
Car: 89 240sx
Well has anyone used or is using a Greddy Rebic on there RB20DET. What are the pros and cons of this. I really don't know much about it I'm just wondering if I should buy it off some guy or not. The main reason why I want it it's so I can avoid the speed cut and control the RPM's.
Well my engine is pretty much stock exept for the FMIC and the custom make intake manifold. Would I really need it if I don't have any mods on it.
The guy told me that the Greddy Rebic controlled Injectors, fuel cut, ignition cut, RPM's, speed cut, and I could also add injectors if I wated to and could contoll them w this .
I plan on using the car for drifting but once in a while take it to the track my goal is to run a high 12 or low 13 w/ Drag radials. Well thanx and LMK what yall think Im still a noob.
Carl H
the rebic is an extra injector controller, nothing more nothing less.i consider it archaic as time has moved on around extra injector controllers...tuning the stock ecu is much more viable.
Stealth-Z
Car: 1991 300ZX
Carl H wrote:the rebic is an extra injector controller, nothing more nothing less.i consider it archaic as time has moved on around extra injector controllers...tuning the stock ecu is much more viable.
Greddy made a piggy back ECU called the Rebic LC. I have one still in the original box.There is nothing in it about controlling injectors. On another note, I have a Rebic II additional injecter controller, so appearantly Greddy liked to use the word "Rebic" at one time.
Carl H
well then, i stand corrected!
Nskylinerb-25
Car: 89 240sx
Stealth-Z wrote:Greddy made a piggy back ECU called the Rebic LC. I have one still in the original box.There is nothing in it about controlling injectors. On another note, I have a Rebic II additional injecter controller, so appearantly Greddy liked to use the word "Rebic" at one time.
mmmmmmmmm I guess the one that I plan on getting is the Rebic LC cause he told me it was a straight plung in to the ECU. Well how good is it and will that help me reach my goals at the track of low 12 or high 13
