Are you using this fuel system now cause I want to use the same set up but I don't know what else is needed besides the rail, inj, and resistors? Did the injectors fit well in the ka24de or did you have to modify anything?emperor_lunchbox wrote:I got some 450cc injectors from a GSX. I was wondering if an FPR is necessary in this set up. I will be getting the projectnissan.com rail and the JGS resistors. I read that I should get an aftermarket FRP, but is it necessary. Also how does an FPR compare to an FMU?
