is adjustible toe and rear tension rod and overkill for daily driving?
smokey240sx
I alignment is pulling pretty bad. I was told that on on my camber is off. I already ordered adjustable ruca for fix that. I'm not sure if i need adjustable toe arms or rear tension rods. I mostly daily drive but wasn't sure if i need it since I did dropped my s13 2".
S14toRPS13
If you need RUCAS to adjust your camber, then you'll need adjustable toe arms and rear tension rods to adjust your toe. Adjusting your camber with RUCAS will throw your toe settings way out of whack without them.
