Yeah, most of the time when they harvest the motor, they just cut the lines leaving part of the line along with the fitting going into the compressor. That is all you need.Rusted_PS13 wrote:the original AC lines from the CA?
Veen wrote:And yes. The radiator from the DE works perfect. I kept mine in there and didn't have to modify it or anything. All the hoses come out on the same side and plug right in with minimal cutting.
Wait. So the SOHC AC pumps from the KA24E will bolt onto the CA18DET?
AFAIK, the compressor bolts up, but the pulley isn't aligned properly so people start shredding belts.Veen wrote:And yes. The radiator from the DE works perfect. I kept mine in there and didn't have to modify it or anything. All the hoses come out on the same side and plug right in with minimal cutting.
all KA radiators are the same fool!r34 gtr wrote:and i thought it was the KA24E radiator that was a direct fit. the DE has the inlet and outlet on the opposite sides, whereas the E has them on the same side, like the CA.
- tim
