Is a week too long to wait before a touchup?
MattB
Car: 2001 Infiniti I30A
Something hit the hood of my car yesterday pretty hard, and I'm concerned that the chip may have gone down to bare metal (the chip is pretty deep and looks kind of white/grey and the car is KR4 grey, can someone tell me what bare metal looks like?). Anyway, I've ordered a paint touchup pen but it won't be here for a week. Will I run the risk of rust starting within a week?
Q451990
Bare metal looks like, well... bare metal. What you describe sounds more like the primer layer. I don't think you have much to worry about. If it does rust a little in the week you can touch it up with a little Loctite Extend (available at Lowe's or Home Depot) for about $5 before you touch it up.
Heath
MattB
Q451990 wrote:Bare metal looks like, well... bare metal. What you describe sounds more like the primer layer. I don't think you have much to worry about. If it does rust a little in the week you can touch it up with a little Loctite Extend (available at Lowe's or Home Depot) for about $5 before you touch it up.
Heath
The problem is that my car is pretty much the same color as bare metal (metallic grey), so it's hard to tell. I may just end up having the dealer overnight the paint to me, because then I could get it by tuesday instead of friday...how long does this stuff usually take to dry?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Temperature and humidity variable.
Sand it and go thin with multiple layers.
MattB
maxnix wrote:Temperature and humidity variable.
It's going to be somewhat humid and in the 70s-80s for temperature (southern VA). I'm not sure it's something I can really sand though since it's so small that I don't think I could get anything in there without affecting adjacent areas.
qship96
Car: 1996 Infiniti Q45
Smear a dab of white lithium grease or similar on the spot until you can get the paint. When you are ready to touchup the chip, clean the area by washing with soap/water, then wipedown with alcohol to remove any trace of the grease or wax on blemish.
The covering of chip with grease will prevent oxygen & moisture from reaching the metal, preventing rust/ oxidation.
MattB
qship96 wrote:Smear a dab of white lithium grease or similar on the spot until you can get the paint. When you are ready to touchup the chip, clean the area by washing with soap/water, then wipedown with alcohol to remove any trace of the grease or wax on blemish.
What about putting a dab of wax on it? Would that work as well?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Yes, that is fine. Just remember to remove with a solvent.
The sanding is to bevel the adjacent paint so by thin layering you can get a good blend and adhesion.
MattB
maxnix wrote:Yes, that is fine. Just remember to remove with a solvent.
Would rubbing alcohol be safe to use as a solvent?
driverdriver
Car: NICO's longtime resident Canuck!!!
Use denatured rubbing alcohol. Its less harmful to paint. Most large pharmacy chains carry both. If you can't find it, talk to a pharmacist.
Also beware that in high humidty-high temperature, rubbing alcohol will vaporize in air before hitting metal. Make sure the metal your treating is cool to the touch.
