Q45tech wrote:Dirt [worn clutch/friction material] is one thing and fluid degradation from heat, shearing and oxygen is another. Internal seal changes from heat is a third.
I have gone back to conventional bulk ATF [Exxon/Mobil 111h] with Lubeguard flushed every year just easier for me.......as the ATF comes out almost as new color. But then again I've only got 100k on transmission number 3.
With the engine at 305k I expect some serious failures some time in the next 3-4 years.
actually, i have a quick question.
last time i did a flush, i drove the car for 15 minutes with the BG at quick flush in, and then let the car sit [not running] for an hour before i actually connected the bg machine.
is it bad to let the bg flush solvent sit in the trans [1 hour] or drive while it is installed?
[maxima trans]
i ran through all the gears while connected, and the flow meter in the sight glass indicated very good pressure [dont remember exactly. it was better than most cars we hook up]
