T45 wrote:First off there is no auto trans pilot bushing. The torque convertor bolts to the flywheel and the flywheel is hubcentric to the crank. The trans input shaft goes into the torque convertor, not the crank.
Are you using a TT trans or NA trans? I used an NA trans and TT flywheel. I welded my bellhousing using VH auto bellhousing grafts and the transmission is flush with the engine. I still had to shim the flywheel with a stock spacer to get it to fully engage with the starter.
What trans and flywheel/clutch are you using?
I bought a N/A transmission, it came with the flywheel, clutch, pressure plate, transmission, driveshaft, and starter.
I made the adapter plate in my garage and hacked off a 1/2" of the bellhousing. I did find that there is a bushing for the torque converter on the end of the crank. I took me an hour to get that thing out. Its 1/4" thick and a snug fit. With that removed the 300ZX pilot bushing went in with no problems. I then used the shim from the auto flexplate ( that is between the bolt heads and flexplate) to move the flywheel out farther, that did the trick, no more sloppy play between the pressure plate and release bearing.
I don't know how it fixed itself, but the inputshaft on the transmission doesn't hit the crank anymore, possibly the auto pilot bushing was the cause, lol.
