so we are kinda in the same boat, only yours probably runs and mine doesnt. but thats really weird Is yours stock? of not, whats parts are on it?wzntha wrote:my blacktop has a thin o2 sensor, so maybe we should trade??? hahah,jk. i've asked if having a different o2 sensor would require different wiring, but i didn't get a straight answer from anyone.
its ok, to answer your first question, i would like to set my tps, but it is from an automatic, and i dont know how to set it. as for other issues, after you rev the motor the idle will drop really low (about 200-300rpms) and then jump back up to normal idle. also if you monitor the exhaust air at the tail pipe, to motor seems to mis, and stuter, kinda like it has cams.exhsturbine wrote:im not really sure. but i think that the skinny is for redtops, and the fat is for the blacktops. i know that this info doesnt really answer your question as to whether or not mixing and matching works. but i dont think it would cause a problem. perhaps your problem of running rich and idle is caused by a boostleak? is your tps set correctly? are you experiencing any other issues?sorry for answering your question with... a question.
zer...age=3Project240 wrote:With the O2 sensor, I'm not sure how compatible the fatty sensor is with a redtop motor/ECU. It'll still run but probably won't run as well as it should (I'm running a fatty O2 on a redtop ECU and I'm getting some backfiring and bogging, although that could be due to other issues I'm having at the moment).
Tulsa_S-13 wrote:As long as you're using the correct elbow, it won't be a problem. Both styles use a heated o2 sensor and work off the same voltage differences and have the same electrode.
I'm assuming Nissan switched to the 'fat' style for cost and manufacturing purposes.
also... recirc bov?
it's stock, so everything came that way. my car runs a bit sluggish, idle also drops to like 400 rpm, and i can hear it misfiring when i'm standing near my exhaust, but i think that's because the connector on the cas is partially broken, lol. i don't think the o2 sensor can cause major problems though. if you haven't yet, you should probably check all the electrical connectors.redsx13 wrote:
so we both still need a straight answer, anyone??
1.does idle drop down for a moment after you rev it, and then come back up?wzntha wrote:
exhsturbine wrote:how is the mechanical timing? you say it sounds as if it has cams in it... i had set mechanical timing wrong once... not too far off. and it sounded as if there was a large duration and lift set inside.
the plugs are brand new, i checked for boost leaks, and my ecu is not throwing any codes at all. Im pretty sure the ignition system is grounded. (doesnt that ground connect to the intake manifold or somewhere around there).exhsturbine wrote:well thats ignition timing.... but im sure your mechanical timing didnt just *jump* out. did you check for boost leaks, or get any other codes? all of your plugs are good, coilpacks are okay. ignition system is grounded. all of the basic easy stuff?
If my tps is off, it cant be that bad, cus my car doesnt really do that.otterman wrote:My TPS was off pretty bad once.
Here's what happened to my car.
You had basically two settings: Full throttle or brake.
You'd have to mash the gas pretty hard for it to go, and it would only go full throttle. Then as soon as you let off, it would be like you're slamming on the brake. It was pretty ****in annoying.
