wildacexxx wrote:i've seen alot of posts on here about guys having problems with running on 3 cyl. and smoking. is a full rebuild on the ca really necessary? this can really be a deterent.
A full rebuild is not always necessary. First of all, you spent X amount of money to buy an engine nearly ready for direct installation into your US spec S12,S13,S14. Of course you may want to check and or change the little things such as water pumps, timing belts, cam seals, front crankshaft seals, and rear main seals. If you're one of those people that purchased a motor/motorset and left it sitting in your garage past the amount of time alotted for warranty by your engine supplier, then you go a step further from what I previously stated and inspect the rod and main bearings. Rarely do CA18DE/DET oil pumps fail, but if you want to get technical, change it as well.
If you immediately open up an engine that has warranty, you've just voided it ! And maybe when you open it, you find some melted pistons, etc, etc, etc. It is best to do your compression test 1st, then leak down test and if they both yield good results, enjoy what you've spent your money on. Don't be foolish and go tearing the thing apart because you want peace of mind. That same desire for peace of mind is gonna cost you more down time and more money out of your pocket for what was supposed to be a budget install.
I've had the distinguished opportunity of owning about 5 of them and I can say that the worst of the bunch is the one that is in my g/f's sentra right now. The only reason why I say it's the worst one is because it was a RWD unit that I had to convert to FWD and since it had the fan clutch on its water pump, changing it to the FWD scheme caused the water pump to fail within 10 miles of driving. I actually boost this thing recklessly to 20psi of boost when I do drive it and it's all done on pump gas. That's right! A virgin CA18DET that never had it's oil pan opened or it's head popped-off is withstanding the abuse that I'm offering. Coupled with over 55 nasty dyno runs, I would say why mess with something that isn't broken. Howeverm it is your choice........
Dee
