ConradoIII wrote:Whats the diff between just a no name intake system and like the nismo and stuff like that
One of the major differences is not really the intake pipe but the quality of the filter. Of course you would want either S/S or Aluminum Alloy but more has to do with the filtering.
K & N is considered to be a better quality unit which boast High Flow Filtering because of the charging system oil they use and its superior in dirt catching qualities while maintaining excellent back pressure
Donaldson make an incredible filter that is used in coal mines in the equipment that boast 10 micron filtering with even flow
AEM has Dryflow Oil-Free Air Filter systems
Good luck lots of choices out there to view. You can almost always go right with NAME BRANDS
