Is a fuel pump necessary?
nissan
t3/t4370cc injectorsS-AFC7lbs on a ka24e
Could I run this without a fuel pump?And would this be safe or would i need anything else?Feel free to make any comment.............
MarkEmark
Car: fully-built '95 240sx KA-T
I ran 7 psi all summer with the stock fuel pump--I've heard from various sources that our pump is pretty adequate; however, it's a good idea to eventually upgrade it, as I have...
Drift Machine
Car: 1991 KA-T 240sx
Yeah pretty much what MarkEmark said, it can handle it. But I would just do it for reassurance, seeing is how they aren't all that exspensive.
SingleCamSam
On an older car like an S13 i'd buy it for security. However the S14 fuel pump has been proven to be able to support 540cc injectors at stock pressure.
Touchdown038
Car: Computers, cars, sports
Yes, you DO need a fuel pump in order to run your car. :)
But yeah, stock pumps are enough for 7psi I would think.
AceInhole
at 7psi my car was leaning out on the stock pump. i'd change it to be safe, as some pumps may not be in as good condition as they used to be.
daniel240
Car: cars/motocross
it also depends on how many miles are on your car. if youve got over 70k i would change it. if not then 7psi it would be about maxed out. its safe just to change it, its only $100
cyrus240sx
Car: 95 240sx with five lug swap, rims, suspension, I H E, remote start, too bad its auto
now what would you change it with?.... a 300zx fuel pump?.... would that work?
Touchdown038
Walbro 255lph. $85 shipped on eBay.
240marcuSX
Car: E34 525i
E46 M3
^ word, i just bought mine yesterday off ebay. the good thing is that theyre ALWAYS on ebay with by-it-nows. Yeah ive heard of people using 300zx fuel pumps.
DriFt3r
Car: Racing and Drifting
where can i get a pump for the s14? ebay only has them for the s13
LongIsland240
Car: 92 S13 Hatch
nissan wrote:t3/t4370cc injectorsS-AFC7lbs on a ka24e
You could, but for $85 and about an hour (if you take your time) to change it......is it really not worth doing in your opinion?
MarkEmark
LongIsland240 wrote:You could, but for $85 and about an hour (if you take your time) to change it......is it really not worth doing in your opinion?
Yes, and I suggest changing it on an EMPTY tank, not 1/2 a tank like I did. That gasoline smell really gets to you-i developed a mild cough after doing that and my fuel injectors--see if you can get a surgeon's mask or something when doing it because, in an S14 anyway, you have to thrust your hand in there and fish it out-I was sitting in the trunk when I did this.
daniel240
Car: cars/motocross
MarkEmark wrote:Yes, and I suggest changing it on an EMPTY tank, not 1/2 a tank like I did. That gasoline smell really gets to you-i developed a mild cough after doing that and my fuel injectors--see if you can get a surgeon's mask or something when doing it because, in an S14 anyway, you have to thrust your hand in there and fish it out-I was sitting in the trunk when I did this.
i agree, mine was full when i changed mine, and i had my whole arm under gas trying to fish it out. and my car smelled like gas for a month. plus its more dangerous having a full tank.
