Like it but not quite, only the speedometer is digital the rest is analogue with needs for the temp, gas. Little lights for the various things like high beam, anti lock brakes, door openning, etc. The odometer is just a normal spinning oneMangudai wrote:? I know what the hud is and the read out on the windsheild. But is the actual cluster like this?
yeah you can swap clusters. just make sure you get the correct cluster for your engine. you have sohc? get sohc cluster from a sohc coupe. have dohc? get dohc from dohc coupe. the hud comes with it, but you can turn it off.not sure about the color change.Mangudai wrote:Thanks a lot guys. Thanks for the picture LaynLow, thats awesome!
So this what people were talking about when they said it was possible to swap that over to say, the fastbacks correct? I wouldnt want the hud just the actual digital speedometer.
I have another question....is it possible to change the color to say, red? Im assuming that its white normally.
Thanks again, and I apologize if this has been covered already but every time i searched I only found threads on the HUD.
