Is a '97 OBD II JWT ECU compatible with a '95 OBD II KA24DE?!?
MarkEmark
Car: fully-built '95 240sx KA-T
I've been looking for a JWT ECU programmed for 50 lb fuel injectors and a Cobra MAFS for quite some time right now, and they are few and far between, especially OBD II for a manual transmission...My engine is a '95 OBD II KA24DE. I found one on ebay for a great price (don't even think of taking it, you bastards), but the auction ends in one day so I need a quick answer...
Anyway, the ad description says:
"96 240sx ECU tuned by JWT (Part number E2401-TMF5F) designed to run a turbo on a KA24DE utilizing a Ford Cobra MAF sensor, and MSD 50lbs injectors. Was used flawlessly for about a year in conjunction of F-Max Stage II Turbo kit on a 97 240sx. This mod retails for about $595 at JWT and is setup for a manual transmission drive train only"
So it seems that he got the '96 ECU and had it programmed for his '97 KA-T, but since both '96 and '97 are OBD II I guess that means they're interchangeable?
My question is: He used it on a '97 KA. Assuming my '95 KA is OBD II and his '97 KA is OBD II, would there be any problem running this JWT ecu tuned for a '97 engine on a '95 engine?
I wouldn't think there'd be...
What's strange is that the part number he gives is supposed to be for a '91-'94 (OBD 1) KA...But this must be some sort of mistake because it was used on a '97.
To sum up: Bottom-line, is a '97 OBD II KA ECU compatible with a '95 OBD II KA?!?
Thanks...
Structure240sx
all s14's ecu's are compatiable with one another. if you look on jwt's site they show what needs to be done to use it on 95's i beleive with OBDI. only thing is the a/c wire. if you dont car about a/c then there shouldnt be anything to do. check over jwt's site
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
...and there's nothing to do when putting a '96 ECU into a '95 car.
To run it in a '97, you make a couple wiring moves. But the ECU will bolt right into a '95...but since there are a few missing sensors on the '95 motor, you'll always have a CEL.
Buy it.
- Brian
MarkEmark
Nice, I got that sucker for $335, and should make all my money back when I sell my existing ECU...
It's too bad that bigger fuel injectors/MAFS/fuel rails cost so damned much.
I might start a separate thread on this...but is it possible to use 550 cc side feed injectors instead of the 50 lb/hr (525 cc) top feed injectors with the JWT ECU programmed for 50 lb/hr fuel injectors? Being able to use side feed injectors would save the hassle of changing the fuel lines/rails and would probably be a cheaper route, especially since I believe structure240sx is still selling his at a good price..
Is the 25 cc more for each fuel injector going to make that much of a difference? Would it just run richer? I could always lower the fuel pressure a couple of psi to make them flow 525 cc/min. BTW, I know there's some resource out there showing increases/decreases in cc/min flow vs. increase/decrease in fuel pressure in the rail
WDRacing
My buddy ran 310cc injectors on his RB20 which is only programmed for 270's. It was a tad rich, but no smoke in the exhaust.
You may be able to trim the base fuel pressure down a lb or 2 just to compensate.
:: orion ::
To determine new injector flow:
Take the square root of the new base pressure diviided by OEM base pressure.
So to get 555's to run like 525cc injectors...lower the base pressure ~4psi.
Take the square root of ( 39.5 / 43.5 )...which is the square root of .908...which equals .953.
95.3% of 555 = 528cc.
So lower your base pressure ~4psi, and you'll be set.
Typically, I don't like reccomending lower base fuel pressure...but try it...4psi isn't that much.
- Brian
MarkEmark
Yeah, I don't really like the idea of lowering it 4 psi either because it could aversely affect the atomization of the fuel/the spray pattern...
Realistically, would it really run a LOT richer if I kept the fuel pressure the same and used 550 cc injectors (not 555 cc)? What about just lowering it 2 psi instead of 4? I guess it would, and given the inherently rich nature of JWT's programs, I'm not sure that's something I want...
I guess when all's said and done it'd only cost $100 more to go top-feed, which seems worth it to have the fuel curve more optimized.
